Need Help With Spokes.
Laurence--Trials
So i've been shown spoke calculators before and i fail at them before anyone mentions that :$
I'm currently running duel standard onza zoot wheels and i want to make the following changes.
Front wheel:
Rim: Onza zoot
Spokes: standard black
Nips: standard onza zoot green
Hub: Onza non-disc open green (onza zoot standard.)
Cross: Two cross.
which i want to change to:
Rim: Onza zoot
Spokes: If i can, keep the same, chances are i wont be able to though :(
Nips: Standard onza zoot green
Hub: Trial tech race sealed disc hub.
Cross: Dont mind, would like no cross if it means i can use the same spokes
Rear wheel:
Rim: Onza Zoot standard
Spokes: Onza zoot standard black
Hub: Onza sealed green non-disc hub.
Cross: Two cross
Which i want to change to:
Rim: V!Z Single wall 24"
Spokes: Onza zoot standard black if possible.
Nips: Standard Onza zoot green
Cross: Dont mind atall.
Chances are i'll have to change the spokes in the front wheel but if i can i want to avoid changing them on the rear. Any help will be appreciated.
Edited by Laurence--Trials
  On 10/30/2011 at 6:13 PM, Azarathal said:
Planning on going disc or maggy? From what I've seen V!Z rims are shite for grinds.
I already knew that, thanks anyway though :) I'm going maggie with smooth rim :)
  On 10/30/2011 at 6:14 PM, Mark W said:
It isn't anything like the 19" or 26" older style Viz rims in that it's basically just a 24" Try-All rim.
Any help on the spoke situation mark? I was hoping a tart would reply. So its pretty similar to the try-all HOLE rim?
To tartybikes: (when your next working, ifff you can) could you find the width of the holes in the V!Z rim so i can choose some rim tape for it?
I've been a little pest to you guys recently :$
EDIT: I assume 38mm width would be enough?
  On 10/30/2011 at 9:15 PM, Revolver said:
The great thing about sellotape is that it comes in quite long rolls so if there are gaps you can just do another few layers.
Then you get shit sticking to the side facing out of the holes :(
Get something like an old pillowcase / clothing etc, cut strips out and wrap tape around it? That way you get awesome looking tape without shit sticking to it.
Or buy proper rimtape...
Or, you put the first, outside layer the other way up.
