Koxx Boxx
Canardweb
I have been more or less looking for a Koxx Boxx frame for the last two years. I found this one which is basically brand new and made an awesome build with brand new components.
Geometry: 1095; 380; +50
Weight: 8,4 kg
Koxx Boxx frame
Try-All 2009 rim brake Forxx forks
Echo SL freewheel
Try-All 175 mm cranks
Trialtech half bashring
Trialtech Z610 HX chain
Echo TR 2010 platform pedals
Try-All bottom bracket
Rockman / Try-All Hole No War Single Walled rims
Bonz rear hub
Try-All front hub
Sapim spokes
Kenda Small Block Eight front tire
Schwalbe Big Betty rear tire
2005 HS33 rim brakes
Custom levers
Try-All CNC clamps
TNN LGM pads
Try-All NUC stem 125 mm x 25°
Karbon concept Try-All No War 2011 carbon bars
Trialtech thin foam grips
Try-All No War headset
Edited by Canardweb
Not being rude but...how much and where did you find it...i also think there lovely frames.
Second hand. It was the second bike of a starter. He had two Boxx. He barely used that one. None of the two have cracked in three years! I have had a very good build for 750 euros and I just built it with new parts! It is a very expensive bike right now...
