Julius Czar Posted October 30, 2011 Report Share Posted October 30, 2011 (edited) Just got a CK hub off a mate and it has what looks like a HD axle, but the fun bolts don't fit in to it, I've taken the axle out and it looks like the HD axle on Tarty, I thought you could run fun bolts with this axle? There are these thread insert thingy's in there, do i take them out? Or have i got the wrong axle? Any help would be largely appreciated. Cheers, Kieran Edit: it's the BMX axle Edited October 30, 2011 by Julius Czar Quote Link to comment Share on other sites More sharing options...
ezgonzo Posted October 30, 2011 Report Share Posted October 30, 2011 irq the bmx axle have a 10mm thread where as the ck fun bolts have a 12mm thread, the bmx axle use's a standard 10mm allen bolt with ally washer instead, here's a link to show what i mean ( My link ), any 10mm allen bolt around 30mm long should do the job fine. Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted October 31, 2011 Author Report Share Posted October 31, 2011 Thanks a lot man Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 31, 2011 Report Share Posted October 31, 2011 I'm pretty sure that the BMX hub uses an imperial thread or whatever it's called. 3/8" perhaps, I recall it being roughly 9.5mm in diameter. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted October 31, 2011 Report Share Posted October 31, 2011 I know the bmx lockring is a pain in the arse imperial so it would make sense for the axle to be just as awkward. Quote Link to comment Share on other sites More sharing options...
