dannytrialskid Posted October 29, 2011 Report Share Posted October 29, 2011 Hi, Braided hose came out for some reason today and can't get it back in. Can you please help? - I've done it so the end isn't frayed and it still wont go in. I presume that's what I've got to do? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted October 29, 2011 Report Share Posted October 29, 2011 Looks kinda stripped. The bit on the end of the hose should screw on to the fatter section next to the slave but that thread looks a bit dodgy in that pic. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted October 29, 2011 Author Report Share Posted October 29, 2011 (edited) Nah, it does work. The arrow on the right, is what I need to happen. The hose wont go into the bolt that I'm holding. Then I can tighten the bolt onto the barb, and it would work. The hose just wont go into that stupid bolt -.-My bad, arrow on the right not the left. :/ Edited October 29, 2011 by dannytrialskid Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted October 29, 2011 Report Share Posted October 29, 2011 Nah, it does work. The arrow on the left, is what I need to happen. The hose wont go into the bolt that I'm holding. Then I can tighten the bolt onto the barb, and it would work. The hose just wont go into that stupid bolt -.- You need to make sure the hose outer doesn't have any frayed bits and it is still nice and tight. Braiding often loosens a bit at the end increasing the diameter and stopping it from passing through the fitting. Maybe try wrapping a bit of selotape round the tip of the hose so that it's easier to slide the fitting over the end of the hose? Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted October 29, 2011 Author Report Share Posted October 29, 2011 Gave up and used my brothers standard Magura hose. Quote Link to comment Share on other sites More sharing options...
