crispyboy Posted October 24, 2011 Report Share Posted October 24, 2011 Can you put them on the bottom,between the frame and then forks ? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted October 24, 2011 Report Share Posted October 24, 2011 Can you put them on the bottom,between the frame and then forks ? Not really. The crown race needs to sit snugly on the steerer which can only happen at the crown of the fork. Quote Link to comment Share on other sites More sharing options...
crispyboy Posted October 24, 2011 Author Report Share Posted October 24, 2011 Not really. The crown race needs to sit snugly on the steerer which can only happen at the crown of the fork. but shorly if i done it up nice and slowly and got it all in place and then tightened it hard ? Quote Link to comment Share on other sites More sharing options...
Revolver Posted October 24, 2011 Report Share Posted October 24, 2011 Try it, let us know if it works. Quote Link to comment Share on other sites More sharing options...
crispyboy Posted October 24, 2011 Author Report Share Posted October 24, 2011 Try it, let us know if it works. go make a video in your sink Quote Link to comment Share on other sites More sharing options...
Azarathal Posted October 24, 2011 Report Share Posted October 24, 2011 Ryan stop being such a fanny, as Revolver said just try it, i'm sure we'd all like to know if works just for future reference. Quote Link to comment Share on other sites More sharing options...
Revolver Posted October 24, 2011 Report Share Posted October 24, 2011 What's with that comment? You want to know if something works... one way to do it is to go outside and try it. Nothing significantly bad is likely to happen - you'll know as you're tightening it up if it's going to break, and you'll know the second you try and turn the bars if the headset will work. Nobody knows how long that setup will work - no-one's done it - so you won't get an answer for that. Quote Link to comment Share on other sites More sharing options...
err Posted October 24, 2011 Report Share Posted October 24, 2011 it might work but it won't work well it'll end up sloppier than the local bikes haddock pasty Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 24, 2011 Report Share Posted October 24, 2011 It won't. The crown of your fork has a little angled edge to it. Your crown race needs to be up against that, otherwise it won't really hold it in place properly when it's tightening up. Quote Link to comment Share on other sites More sharing options...
Sam Moss Posted October 24, 2011 Report Share Posted October 24, 2011 why would you want to do that? Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 24, 2011 Report Share Posted October 24, 2011 hire bb m8 Quote Link to comment Share on other sites More sharing options...
Revolver Posted October 24, 2011 Report Share Posted October 24, 2011 Did you try it when you were thinking of ways to raise your fourplay's BB height? Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 24, 2011 Report Share Posted October 24, 2011 Nah, because slackening the head angle was the exact opposite of what I wanted to do (and because I knew it wouldn't work). Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted October 24, 2011 Report Share Posted October 24, 2011 but shorly if i done it up nice and slowly and got it all in place and then tightened it hard ? Shorly not. 1 Quote Link to comment Share on other sites More sharing options...
super Posted October 25, 2011 Report Share Posted October 25, 2011 Don't know what forks your running at the moment but trialtechs are a little bit longer than most other forks out there i believe. Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted October 25, 2011 Report Share Posted October 25, 2011 Just put a bigger front wheel on. Bout timez 29ers came to trials! Sleeegsss! Is that right? Slegs? 2 Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted October 25, 2011 Report Share Posted October 25, 2011 ^^^^^^^ LOLZ ^^^^^ Quote Link to comment Share on other sites More sharing options...
thispartisrequired Posted October 25, 2011 Report Share Posted October 25, 2011 It don't work well, i knocked me up a similar thing on a real old shitty bike to bodge some forks in, granted it worked but it weren't too great. My method was basically an extension of the head-tube, had I welded the piece of tube to a headset cup it probably would have been a lot better. So maybe a steel headset cup welded to a bit of steel with the right id would be a better solution than some headset spacers Quote Link to comment Share on other sites More sharing options...
