stephen nicolson Posted October 24, 2011 Report Share Posted October 24, 2011 my freewheel still clicks but not as loud as it should be anyone know how to sort it ? Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted October 24, 2011 Report Share Posted October 24, 2011 What freewheel is it? If its a cheap one then theres not much point but if its decent then if you don't want it to last as long, take the lockring off and take all the grease out of it. It will make it louder but will wear quicker. So what would you prefere spending £40 or having a loud freewheel? Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted October 24, 2011 Report Share Posted October 24, 2011 What freewheel is it? If its a cheap one then theres not much point but if its decent then if you don't want it to last as long, take the lockring off and take all the grease out of it. It will make it louder but will wear quicker. So what would you prefere spending £40 or having a loud freewheel? I'd prefer to drown it in GT-85. Job done. Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted October 24, 2011 Report Share Posted October 24, 2011 Oh yeh there is that but wear a mask, GT85 is heavy stuff. Quote Link to comment Share on other sites More sharing options...
stephen nicolson Posted October 24, 2011 Author Report Share Posted October 24, 2011 I'd prefer to drown it in GT-85. Job done. yes i have gt-85 but what should i do with it?just spray it all over the freewheel ? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted October 24, 2011 Report Share Posted October 24, 2011 (edited) Oh yeh there is that but wear a mask, GT85 is heavy stuff. It's only like wd-40 - a maintenance spray! And you'll want to be directing the hose that comes with it into all the little cracks and crevices where the freewheel rotates. Easy as Edited October 24, 2011 by dann2707 1 Quote Link to comment Share on other sites More sharing options...
stephen nicolson Posted October 24, 2011 Author Report Share Posted October 24, 2011 (edited) What freewheel is it? If its a cheap one then theres not much point but if its decent then if you don't want it to last as long, take the lockring off and take all the grease out of it. It will make it louder but will wear quicker. So what would you prefere spending £40 or having a loud freewheel? It's a echo SL and it not that old ? Edited October 24, 2011 by stephen nicolson Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 24, 2011 Report Share Posted October 24, 2011 Either GT-85 or thin chain oil will do the trick. Have you ridden in the wet lately? Quote Link to comment Share on other sites More sharing options...
weirdoku Posted October 24, 2011 Report Share Posted October 24, 2011 I don't get why people want a loud freewheel. If it engages fine then there's nothing wrong with it. Unless you like to hear the freewheel engage, I could feel each click in my legs when I rode so never bothered about how loud my freewheel was. Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 24, 2011 Report Share Posted October 24, 2011 It is often a sign that all's not well with a freewheel to be fair, but if your freewheel's working well and is only a little quieter than normal that's not the end of the world... Quote Link to comment Share on other sites More sharing options...
stephen nicolson Posted October 24, 2011 Author Report Share Posted October 24, 2011 Either GT-85 or thin chain oil will do the trick. Have you ridden in the wet lately? yeh i think water has got in it ? Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 24, 2011 Report Share Posted October 24, 2011 Cool - from the factory they have no real lube in them, so if they get wet they can sometimes rust up a tiny bit if they're left wet. That means they don't work quite as well, hence it being a bit quieter. A bit of lube in there should get it back up and running again Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted October 24, 2011 Report Share Posted October 24, 2011 (edited) It's only like wd-40 - a maintenance spray! I got a pretty bad head ache from using it once but that was proberly because it was in a small room and it does smell quite nice. Edited October 24, 2011 by Milo123 Quote Link to comment Share on other sites More sharing options...
trialsrider101 Posted October 25, 2011 Report Share Posted October 25, 2011 I got a pretty bad head ache from using it once but that was proberly because it was in a small room and it does smell quite nice. i agree totally it does smell really nice, back on topic any thin lube will do but gt 85 in my opinion is the best. Quote Link to comment Share on other sites More sharing options...
aener Posted October 25, 2011 Report Share Posted October 25, 2011 Stick a little microphone next to it, an amp inside the front triangle and whack some sick-ass 6x9s on your bars. 6 Quote Link to comment Share on other sites More sharing options...
Object Posted October 26, 2011 Report Share Posted October 26, 2011 Stick a little microphone next to it, an amp inside the front triangle and whack some sick-ass 6x9s on your bars. Wouldn't 5x7s be lighter? Quote Link to comment Share on other sites More sharing options...
aener Posted October 26, 2011 Report Share Posted October 26, 2011 Wouldn't 5x7s be lighter? Ah - yeah. Fair shout. I forgot they made them - just 6x9s are so much more common I guess. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted October 31, 2011 Report Share Posted October 31, 2011 I've always found my freewheel to be a lot louder when it's been drowned in GT85, then it gradually gets quieter until I drown it again. It's kept in my car and I dont ride in the wet so it's rather confusing. It all works well though Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted November 2, 2011 Report Share Posted November 2, 2011 (edited) I got a pretty bad head ache from using it once but that was proberly because it was in a small room and it does smell quite nice. Hummmmmmmmmm hot box with gt-85 ive never tried this. And in fairness if you use wf40/gt 85 your freewheel goes pretty quiet In my experiance Edited November 2, 2011 by Dave Anscombe Quote Link to comment Share on other sites More sharing options...
