BradJohnson Posted October 24, 2011 Report Share Posted October 24, 2011 Right i've bought a magura for the rear of my bike. I've set it up and tightened all the clamps as much as possible. When I pull the brake the slave cylinder slides inside the clamps away from the rim, how can i stop this, also, its happened with 3 different sets of clamps (echo TR, Tensile offset, and magura, if you were wondering I am using the cylinder washers) Please help its so annoying. Quote Link to comment Share on other sites More sharing options...
Blake Posted October 24, 2011 Report Share Posted October 24, 2011 Have you checked the length of the bolts? Quote Link to comment Share on other sites More sharing options...
Azarathal Posted October 24, 2011 Report Share Posted October 24, 2011 Bolts are too long. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted October 24, 2011 Author Report Share Posted October 24, 2011 Bolts are too long. The bolts are what i got supplied with with the magura. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted October 24, 2011 Report Share Posted October 24, 2011 Not every maggy mount has the same depth, try either cutting the bolts or buy some shorter ones Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted October 24, 2011 Author Report Share Posted October 24, 2011 Not every maggy mount has the same depth, try either cutting the bolts or buy some shorter ones Thanks mate. Quote Link to comment Share on other sites More sharing options...
