Pad Material In Cnc Backing
kaybs41282
Cool and do you need to glue them in somehow?
Yeah, by putting super glue into the backing and pushing them in lol. But i dont usually bother with glue. Phat pads are actually designed so you dont have to glue them in. Shame they're shite though. ;)
  • Like 1
best way to get them out of plastic backings is soak them in boiling water to soften up the glue and prise them out with a flathead, if the backing is the same brand as the pad it should just slot in no bother but if you're mixing up different pads and backings you will need to trim them and super glue them in
Also if you do need to trim them and say you need to take 2mm off each of the ridges take 1mm form either side and not 2mm from one side if that makes sence, If you don't then either the inner or outer parts of the ridges won't fit the backings and you will have ruined your pads. You can use the excess rubber you have cut off to make them fit propprely again but thats abit dodgy,
