20" Or 26" Help!
Connor Johnson
Hey guys,
So for a newcomer who's riding a 20", I was wondering about the difference between a 20" bike and a 26" bike. I've heard that a 20" is easier to learn on, but a 26" is better to learn on because it makes you learn technique that is necessary later on in trials riding. Is the difference between the bikes really that big of a difference? So should I get a 26" instead of a 20" if money is no issue, or is the difference not that big?
Thanks,
Connor
I have a 26" and i think its great but the only reason why i didnt get a 20" is cause i am a giant compared to one haha. I originally had a 24" but i wanted to get away from the street side of things but once i got a 26" i managed to learn a lot more on that than i did the 24". A few of my mates have 20" bikes and they're pretty good but then its your own opinion on what you want to ride
you should go for a onza first and then build up a bike once you improve cause onza bikes can take a beating and are good starters
COUGH COUGH ! !
Your reply was totally irellivent, Don't speak because you feel you need to speak because you have to & answer the Question propper
Edited by TryAllTrials
That's my thought on it though everythings got to be within reason. If you are tiny, a 26" will potentially hold you back plus if you can't afford a 26" then you may as well get a 20".
It's similar to BMX V Scooters. Scooters can be good for young kids to learn on, but it's generally considered a bit weird to be riding one when you could be riding a BMX instead. Scooters are just really easy to do a lot of stuff on which kinda takes the fun out of it. Mods are similar.
  • Like 1
Thanks guys for the help, I really appreciate it. I think I'm going to go with the 26" if I can raise the money for it.
Possibly a few on here for sale, seen a few old skool ones on here today but sure you might find a more comp style one. If you find a 2nd hand one with good spec just means you can justify spending the money on something that your quite likely to wreck, good luck with finding a bike bro hope you can get out and ride before the good old Brittish weather changes again! :(
Edit that, Your a Yank. Lucky bugger ;)
When it comes to Dollars i'm not sure whats cheep, would this be in your price range? http://www.ebay.com/itm/USED-Woodman-Trials-Bike-26-Wheels-Chris-King-Bonz-/300611288869?pt=Mountain_Bikes&hash=item45fdd43f25 if not there are other bikes on ebay that are much cheeper.
If you want More rollin' momentum and rollin' tricks I would go for
the 26".
If you Want more Hopping and jumping up and down things go For the 20"
I also think you should start with an Onza. I'm a new biker But and I'm Gettin' a Onza because they are
light and good to throw around.
Hope my Advice is good use. :)
-Daniel
