bobstar4575 Posted October 22, 2011 Report Share Posted October 22, 2011 Hi i am having problems with lining up the pads with the rim. I was thinking it was because it has no washers between the clamps. thanks will Quote Link to comment Share on other sites More sharing options...
Blake Posted October 22, 2011 Report Share Posted October 22, 2011 Have you filed your frame? Quote Link to comment Share on other sites More sharing options...
bobstar4575 Posted October 22, 2011 Author Report Share Posted October 22, 2011 Have you filed your frame? No Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted October 22, 2011 Report Share Posted October 22, 2011 No Sooo,do it? Quote Link to comment Share on other sites More sharing options...
Blake Posted October 22, 2011 Report Share Posted October 22, 2011 Sooo,do it? Where did you find that video? I spent so long looking for it Quote Link to comment Share on other sites More sharing options...
bobstar4575 Posted October 22, 2011 Author Report Share Posted October 22, 2011 Thanks I will do that that Quote Link to comment Share on other sites More sharing options...
Mikee Posted October 22, 2011 Report Share Posted October 22, 2011 (edited) Where did you find that video? I spent so long looking for it At a guess, they searched for it on youtube. I typed in 'tnn hs33' and it was top result. And yeh, filing the frame should do the trick. If your rims braking surface is slightly sloped aswell, the there is also a TNN video showing you how to sand the pads down so it isn't only the top of the pad hitting the rim. This isn't a must do thing though as it will wear itself square on it's own in time. But it you want your pads to work at their full potential straight away, you might want to check out the video. Edited October 22, 2011 by Mikee Quote Link to comment Share on other sites More sharing options...
Azarathal Posted October 22, 2011 Report Share Posted October 22, 2011 Where did you find that video? I spent so long looking for it Same! Trying to use my phone to search for it and gave up after about 10mins Quote Link to comment Share on other sites More sharing options...
