Single Walling A Rim
isitafox
Well I finally got round to single walling my wheel last night so thought id take a few pics for anyone who wants to have a go themselves but is a bit unsure.
My rim is a trialtech sport circle, tartybikes weighs it in at 708g so I was hoping to get it down to around the 620ish mark which is what the single wall sl rim weighs.
I started by removing the tyre, tube and rimtape then refitting the wheel into the frame. I then turned the bike over so it was sturdy and started to cut between the holes with a thin metal cutting disc so I could judge where the internal web that strengthens the rim was positioned.
Once I'd got the middle out I set to work with the same disc trimming the remaining lip as close to the web as possible trying not to damage it and kill the wheels strength completely. I held it at a slight angle to make life easier when I had to file the sharp edges after. I did the right side first so I could easily see where I was cutting then turned the wheel over to do the other side.
Once both sides were trimmed back I went around the cut edges with a file to smooth them off and stop the tube from popping. Make sure to spend some time doing this and get all the rough and sharp edges taken off. Once this was done I brushed the rim off internally and just refitted the tape, tube and tyre, job done!
Finally to justify my hard work I weighed the offcuts (would have been better to weigh the wheel before and after really but I haven't got any scales at work!) and found I'd saved at least 100g putting the wheel slightly below the sl's weight, result!
Edited by isitafox
I gotta ask, was it worth all that effort to save 88 grams?
Yes as ive saved over 88g, at least 100g which makes it a lighter wheel than with an sl rim and getting tyres on is an absolute nightmare normally but now its easy. Plus it kept me busy for a few hours which id otherwise have spent sat lazing about doing nothing anyway.
did you do this in work?
You knows it dude
Nice, neat job dude!
Cheers Ads!
Edited by isitafox
Yeah with a tiny bit of washing up liquid and some minor assistance. Was well hard getting it on properly, had it pumped to 50psi before i could get it set! Was bricking it expecting the pump to explode as its only a cheapo foot pump!!
So you need washing up liquid and a decent pump that can get it up to 50psi, it sounds really easy to get the tyre on :P
After doing this do you need to run a wider rim tape to cover up the cut edge even though you have smoothed them off?
You haven't seen my footpump, was making some horrible creaking sounds as I got near 50psi and i've already nearly stripped the threads off the pressure gauge when it came off once before. No I just used the same rim tape and it's been fine, checked it earlier and it's still pumped up how I left it.
  • 10 months later...
Dremel would take ages! I I used a hacksaw in the end to do mine as I broke my grinder, I seem to have this ability to break anything I touch.
However a dremel with loads of attachments is brilliant for finishing and smoothing the rough edges to prevent punctures. But you can get away with wet and dry paper.
Just depends if you want to get all sweaty.
Wouldn't it be longer still with a hacksaw?
yes. but you can get a really thin diamond cutting disc for about £10 that fits into a drill. takes ahlf as much time as a hacksaw and not as intimidating as using a angle grinder.
you may aswell just go for the angle grinder though, its easy. or are you not a power tool type of guy.
