Dolly 89 Posted October 14, 2011 Report Share Posted October 14, 2011 right i have brought some hs33's and wondered if anyone had a guide to fitting them please? and they are oil bled at the minuite and wondered as i want to water bleed them do i just do it and flush the oil out whilst bleeding? thanks Quote Link to comment Share on other sites More sharing options...
Revolver Posted October 14, 2011 Report Share Posted October 14, 2011 Setting a brake up. Water bleeding a brake in a bath. Quote Link to comment Share on other sites More sharing options...
Dolly 89 Posted October 14, 2011 Author Report Share Posted October 14, 2011 Setting a brake up. Water bleeding a brake in a bath. thanks for that, i have the bits that arch over tyre aswell (the name of them escapes me now :/) how are they fitted asweel please, as for bleeding do i just keep going till all the oil has come out of the brake? cheers Quote Link to comment Share on other sites More sharing options...
Revolver Posted October 14, 2011 Report Share Posted October 14, 2011 The metal thing that arches over the tyre is a booster. You put a washer on each bolt, then the booster, then the long spacers, then screw it through the brake mounts into the frame. 4 bolt boosters can be a bit of a faff. As for the bleeding, you want as much of the oil out as possible. You'll find the water will come out clean after a while, but the next time you bleed weeks, months later, there will be more oil coming out, but that's fine. Quote Link to comment Share on other sites More sharing options...
Dolly 89 Posted October 14, 2011 Author Report Share Posted October 14, 2011 ooh i dont think i have any long spacers, does anyone have a pic of theres fitted so i can have a look and see what they look like to go buy some, thanks Quote Link to comment Share on other sites More sharing options...
