Tyre Pressure?
harlow
PSI is basically personal preference.
As far as I am aware mod/stock riders have lower pressures as they want to tyre to be able to go 'flat' when on obstacles to get more grip, whereas street riders usually run with slightly higher pressures so they can have more rolling speed.
Each person is different through and you will need to experiment a little yourself to find a pressure that you are happy with.
I don't know about mods but i usually run higher pressure when riding natural.. it's quite annoying when bouncing on sharp edges with low pressure.
But like it's told in the previous post, it is your personal choice! try different pressures out, then you'll find out what suits you the best!
  • 2 weeks later...
