Urbans Or Trialtech?
p_ruskin
Really stuck on what to get, yes i have used the search bar but got no real answer, ive had urbans before and they were fine, but do trialtechs merit me spending £40 extra on them?
really want to be saving but are trialtechs worth the cash in comparison?
Yes definately, I wouldn't go back to Urbans after having trialtechs. I've ran urbans on both my mods an stocks and the difference it made swapping was unbelievable, shown even more so as I went from disc to front maggie on both occasions and the trialtechs were so much stiffer even with the extra strain.
I also prefer the geo of them, found it a bit odd at first as when stood up it looks like the front wheel is really far forward from the frame but other than that they ride great.
Right, cheers, i will be using front mag so i think the stiffness may help.
thankyou for the help:)
Seriously?
You've ridden with me... how many time? I can't believe you feel the need to ask that.
I thought I'd been plugging them pretty hard ever since I met you.
Get the Trialtechs. They are without even a hint of a doubt even being a distant relative of the neighbor of the fact that Trialtech forks are the best.
I had a set of Urbans, a set of Lites, Koxx Forxx and two other sets (can't remember what they were), all in one year.
The Trialtechs have now lasted 18 months.
Got quite a lot of gouges taken out of them, and you know full well I'm pretty rough on gear - still perfectly happy, and still dead stiff.
I repeat: get the Trialtechs.
Seriously?
Yeah, but my old Urbans were pretty good and are still holding up on Charlie's, he doesn't quite rag them as much as you really though, it was just a question of should i splash out on the extra money for them kind of thing :)
it´s ok. both 20" and 26" models are super stiff. anyway If you can´t get trialtech then urban is best opinion IMO(If you will get HS model I recomended you booster because these forks are good known for cracking in 4bolt mounts area...)
Edited by AndrewG
Dont get stock urbans, ever! ha
The mod ones are fine really, perfect if you haven't got much to spend
I'm running urbans on my stock, had the trialtechs, and going back to them was a nice change, my urbans are the u6 ones, but when I break these will be getting trialtechs as feel soo nice
I prefer the geo of (stock/26") Urbans to Trialtech, they are similar but my Trialtechs stick out a bit far in front compared to my old Urbans.
EDIT: However Trialtech's are a little stiffer and seem to be better made.
Edited by cai
The older TT forks had 45mm offset, same as Urbans. The more recent TT forks have 40mm offset. I think it's mainly the curved legs that makes them look a bit more sticky-outy.
Dish out for the Trialtechs-you wont regret it. (Y)
get the Trialtechs.
its a no brainer...
Trialtechs all the way... They are the only forks I trust.
go for tiraltech ! they are much more stiffer than urbans (Y)
Trialtechs! They are better in every way! Apart from the weight
Mutherf**kin Trialtechs! Your wrists will break before they do. I had a pair with a 180mm BB7 on a mod, solid.
AAH the decisions!!!!!
WHAT?!
  • Like 1
