lankyri Posted October 8, 2011 Report Share Posted October 8, 2011 evening all any knowledge on these, ive never seen them or how they actually work so any info on price and where i could buy one, it would be for my bt ninja 365 (yeah thats right with the stupid chainstay length) its been hanging on my wall for years and been tempted to build it back up for a project Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted October 8, 2011 Report Share Posted October 8, 2011 Only seen them with Sq taper axles. http://www.sjscycles.co.uk/prestine-threadless-sealed-bearing-bottom-bracket-for-frames-with-damaged-threads-prod16505/ Quote Link to comment Share on other sites More sharing options...
weirdoku Posted October 8, 2011 Report Share Posted October 8, 2011 "Fits to frames with damaged threads, the bottom bracket screws together ignoring the threads and clamping the frame. The frame requires no preparation other than the removal of paint on the flat faces of the frame. You should also regularly check and tighten the cups. The bracket is best fitted with 2 x UN74-S style bottom bracket tools and two people. If your frame is slightly less than 70mm we recommend the use of Sturmey Archer sprocket washers (HMW127) to pack it out." Quote Link to comment Share on other sites More sharing options...
