Echo Press In Bb Bearings.
Matt Vandart
if im honest i really dont see the point, my bmx uses the same kind of thing and iv gone through about 3 bb's in a year and iv had the same one on my trials for about 4 years, i think its just a way for manufacturers to keep costs down with the price of everything going up these days
Lighter, simpler, less to maintain, less cost to make etc.
If you have quality bearings and axle it'll last, just like other BB's
I was thinking about these type of BB and was wondering what you thought about them stretching the bb shell out (ovalising it).
What do you think?
Is it likely do you think?
If you have one how has yours held up?
We've sold a significant amount of Echo/Zoo frames that use the Spanish BB over the past year - no issues so far (not to mention the Echo Urban 24" and Adamant/Czar frames that used the Spanish BB over 2 years ago).
BMX BBs are a lot different. Their bearing life depends a lot on the length of the tube spacer between the bearings. If it's a tiny bit too long or a tiny bit too short then you'll kill bearings really easily. I went through one Spanish BB in about 2-3 years. They're becoming the norm for BMX frames now as they're pretty well proven to work fine.
As far as I know bmx bb's are smaller than standard MTB bb's
They aren't. A Spanish BB bearing has an outer diameter a little larger than the actual shell of a Euro/MTB BB, let alone the actual bearing itself.
they vary, 'mid' is the usual size wich is larger than like a threaded bb, and 'spanish' is about the same size as a mtb bb
See above.
Mostly because the force will be on a smaller area, as in the bearings are narrower than the cups of a mtb bb.
The bearings are a touch narrower than the cup of a BB, but the actual bearings are wider than the normal bearings of a standard MTB BB.
After seeing the Spanish BB system used in BMX so much, and seeing how nice and simple it was, I hoped press-fit BBs would become the 'norm' in the trials world. Larger, longer lasting bearings, no concerns about BBs loosening, no concerns about cross-threading or stripping your BB shell, approximately the same weight if not lighter for a stronger BB with bigger bearings. Pretty much exclusively plus points. The only negative at the mo is the lack of options available, but if more companies take up this idea then good things will come of it.
