cunny12345 Posted October 8, 2011 Report Share Posted October 8, 2011 Hi guys, i have recently had a fresh grind and new parts for my magura and also a fresh bleed, just went for a quick ride this morning and the brake wont hold at all, oh yeah im using tnn baeleys, any suggestions on what to do ? thanks matt. Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 8, 2011 Report Share Posted October 8, 2011 Are the pads hitting square on the rim, is the brake properly bled? Quote Link to comment Share on other sites More sharing options...
cunny12345 Posted October 8, 2011 Author Report Share Posted October 8, 2011 yeah there hitting square and yeah its properly bled :/ Quote Link to comment Share on other sites More sharing options...
Revolver Posted October 8, 2011 Report Share Posted October 8, 2011 Did you grind with the tyre on? Have you given it time to bed in? Quote Link to comment Share on other sites More sharing options...
cunny12345 Posted October 8, 2011 Author Report Share Posted October 8, 2011 nah the tyre was off, what do you recon i should let it bed in abit? Quote Link to comment Share on other sites More sharing options...
Jake. Posted October 8, 2011 Report Share Posted October 8, 2011 Yeah let it bed in a bit, my cousts didn't hold or bite for the first few hours I had them. Then they gradually got better. Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 8, 2011 Report Share Posted October 8, 2011 its always best to grind with the tyre on, if you take it off, you'll cover your rim in tyre gunk and ruin the grind. Quote Link to comment Share on other sites More sharing options...
cunny12345 Posted October 8, 2011 Author Report Share Posted October 8, 2011 ahh ok cheers guys, thanks ali i will keep that in mind Matt. Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted October 8, 2011 Report Share Posted October 8, 2011 try using the tarty guide about grinding also keep the tyre on like ali said, what rim are you using because some rims have a slight angle on them you can barely even see it by eye but it just means your pads take a little longer to bed in squarely to the rim, other than that i really don't know if you say its all bled and set up right Quote Link to comment Share on other sites More sharing options...
