Knottyloxx Posted October 5, 2011 Report Share Posted October 5, 2011 Does anyone know if maguras fit on a pair of sidekick forks?? might have to buy another pair of forks as they are all ive got for my 26 :/ the brake mounts are x2 bits of metal sticking out the frame, not the two holes on top of one another?? Sam Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted October 5, 2011 Report Share Posted October 5, 2011 you can but you will need to buy adaptors, these Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted October 5, 2011 Report Share Posted October 5, 2011 I used to in the good old days and yes they work fine with EVO adapters. If you bought a generic HS 33 then you should already have these...hopefully. The extra height of the forks compared to standard trials forks used to be lovely when i ran them on a stock all those many years ago. Quote Link to comment Share on other sites More sharing options...
Knottyloxx Posted October 5, 2011 Author Report Share Posted October 5, 2011 looks like theyve already got em on there??? http://www.ebay.co.uk/itm/220868043407?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_500wt_1202if i need to get the adapters, i might just get some new forks as these sidekicks seem REALLY heavy!! Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted October 5, 2011 Report Share Posted October 5, 2011 Yep, they've already got the adapters. basically your sidekick forks have V brake mounts, and maguras as standard use the EVO mounts to fit on to V brake mounts. 4 bolt mounts are what the majority of trials frames and forks use as it offers a more secure and uniform fit. Also, you can get the brake set up perfectly square to your rim relatively simply. The sidekick forks are heavy and they're also the equivalent height of 100mm travel suspension forks so will affect the geo of any trials frame. If you're running them on a small hardtail/jump-bike sort of set-up then you might be okay. I used to run them a long time ago on the original Onza T-rex (silver and blue frame edition - oh yeah) and they were fine for that, but a lot has changed since then so it's going to be a matter of personal preference. Quote Link to comment Share on other sites More sharing options...
Knottyloxx Posted October 5, 2011 Author Report Share Posted October 5, 2011 your so god damn helpful!!! haha, well im using an old saracen xile frame ive got lying around, resprayed and cleaned up, should work a treat, im just building an old skool type bike style that i used to ride back in the day. still not back to work due to my broken wrist so im just keeping busy really, gunna go balls out and get a 24 when im working again!! and your right, ALOT has changed!! when i used to ride trials when i was 15 u were lucky to get a v brake booster and a chain stay protector from MBUK!! haha Quote Link to comment Share on other sites More sharing options...
tdubz Posted October 8, 2011 Report Share Posted October 8, 2011 Keep your costs down and maybe run a v brake on front? Quote Link to comment Share on other sites More sharing options...
