Hope Mono Problems
stuie
IV taken then calliper apart cleaned it all as the pads where not retracting. Put it all back, went to bleed it all and I couldn't take the top cap off the leaver. The correct size Allen key just wouldn't work (iv had it off before)
Any way it can be kinda bled from just the bottom...more than likely not but no harm in asking.
Has any one else had this problem.
Thanks.
Stuart
Have you rounded the allen key heads on the bolts? They were really easy to round so I suggest making a slot in them with a hacksaw, so you can get a screwdriver in there to undo them and replacing them with THESE torx head bolts.
Edited by Mikee
