Acid Diping
Azarathal
Hey guys, looking at getting my frame acid dipped just so I can get that pimp polished look, I'm going to phone around tomorrow whilst work is quiet but I'm wondering from first hand experiances how its been for you?
By that I mean how well was the finish once it came out? Did it need polishing at all? How much was it when you got it done? etc.
Cheers, Mikey.
Nitromorse, working your way up with different grit sandpaper and then polishing or acid dipping (if it is even the correct term) and having it come out (as far as I know) polish... Hmm touch choice.
I'd rather pay £25-30 to drop something off and pick it up then pay £10-15 and then waste a lot of my own time doing a halfarsed job.
Ah fair enough, thought that acid dipping was probably somewhat related to nitromors. It's up to you, depends which you'd prefer.
I would recommend nitromors though, as I've seen how great it's made some frames look. Check these two threads out, rawed Onza Ice, rawed Zona Zenith. <-- However the guy that did the Zona Zenith ended up shot blasting it, then sanded it. Up to you.
