Possible To Straighten The Disc Tabs On A Hub ?
peggysue
Going through the last 4 brand new rotors I've had they all have a bend from new and rub making setting up the disc brake trickier ... Having a closer look tonight it seems that its not the rotors that aren't true but the 5 little tabs on the hub don't seem to be flat with one another ...
Is there a way of levelling them out perfectly ? It would seem a very tricky little job as its probably the tiniest amount that needs to come off .
Cheers
