kristaps Posted October 1, 2011 Report Share Posted October 1, 2011 The best bike I had ever had. So comfortable Specs: Frame and Forks - Frame: Because Simple (modified) - Forks: Because 24’’ (modified) Wheels - Front hub: Monty - Rear hub: Echo TR (modified) - Chain tensioner: Monty Alu Snail Cams (modified) - Front rim: Alexrims DM 24 (modified) - Rear rim: Echo TR (front rim) 39mm (modified) - Spokes: Sapim butted -Spoke nipples; Halo red - Rim tape: Home made - Inner tube (front): 24’’ cst - Inner tube (rear): 24’’ cst (will be 20’’ SL) - Front tyre: Schwalbe Smart Sam (modified) - Rear tyre: Schwalbe Big Betty Brakes - Front brake: Magura HS33 orange limited, zhi brake mounts, 4finger lever blade (all modified) - Rear brake: Magura HS33 orange limited, magura brake mounts, 4 finger lever blade (all modified) Drivetrain - Cranks: Rockman 165mm - Freewheel: Echo SL - Chain: Shimano hg8 - Rear Sprocket: Echo 15T - Pedals: Echo SL 2011 model (modified) - Bottom bracket: Try all (modified) - Bashring: Zhi L (modified) Steering - Headset: ZHI SL - Stem: Monty carbon - Grips: Merida - Handlebars: Trialtech Sport Hi Riser - Stem spacers; Try all & Trialtech carbon Titanium/Al bolts Weight 8.5 kg Quote Link to comment Share on other sites More sharing options...
joakin Posted October 1, 2011 Report Share Posted October 1, 2011 my god ! that's sexy Quote Link to comment Share on other sites More sharing options...
kaybs41282 Posted October 2, 2011 Report Share Posted October 2, 2011 Very very nice Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted October 5, 2011 Report Share Posted October 5, 2011 Looks lush with the orange maguras. Quote Link to comment Share on other sites More sharing options...
