Flames35 Posted September 30, 2011 Report Share Posted September 30, 2011 If I build a rear wheel with the Hope Pro 2 Hub (disc mount) can I still use my HS33's? Quote Link to comment Share on other sites More sharing options...
Franksx2005 Posted September 30, 2011 Report Share Posted September 30, 2011 Yes as longs you frame has mounts. Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted September 30, 2011 Report Share Posted September 30, 2011 Yes as longs you frame has mounts. And the rim isn't disc specific, but if its a trials specific rim you should be fine Quote Link to comment Share on other sites More sharing options...
Flames35 Posted September 30, 2011 Author Report Share Posted September 30, 2011 Many thanks guys. Still learning. This is the one. http://www.tartybikes.co.uk/135mm_free_hubs/hope_pro_2_trials/c148p10058.html Going to put it on my DX 32 rim with red and black spokes. Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted September 30, 2011 Report Share Posted September 30, 2011 rim may be slightly thin if your frame is modern but if it is older it wont matter. Quote Link to comment Share on other sites More sharing options...
Flames35 Posted September 30, 2011 Author Report Share Posted September 30, 2011 It's a Phase 1.2 frame. Quote Link to comment Share on other sites More sharing options...
Joshm1991 Posted September 30, 2011 Report Share Posted September 30, 2011 (edited) Yeah i'm running a Hopey on my Phase!! it works fine with rim brakes!! I love it!! Edited September 30, 2011 by Joshm1991 Quote Link to comment Share on other sites More sharing options...
Rockman Posted September 30, 2011 Report Share Posted September 30, 2011 If I build a rear wheel with the Hope Pro 2 Hub (disc mount) can I still use my HS33's? you sure the DX32 is has 36H aswell ? Quote Link to comment Share on other sites More sharing options...
Flames35 Posted October 4, 2011 Author Report Share Posted October 4, 2011 Yeah i'm running a Hopey on my Phase!! it works fine with rim brakes!! I love it!! Cheers Josh. What size chain rings are you running on the front and back and are you single speed? Quote Link to comment Share on other sites More sharing options...
