Screw On Sprocket Removal
bobstar4575
Often the case - if you keep the tyre on (and inflated) that usually helps a surprisingly large amount.
Sounds surprising till you think of the numbers, with the tyre on and inflated the radius (so the length of your 'lever') is 13" on a stock wheel, so without must be about 11" which means you get an extra 18% leverage with the tyre on...
Dunno why I bothered to work or write that out.
It made for an interesting read, I'm glad you did. ^_^
