09' Hs 33 Braided Hose Fittings
chris4stars
I have the braided hose crossover & rear brake cable for the HS33 (the model before the new '11 one)
The hose at the lever end started to leak so i needed to cut it off (shortening the hose a little) and refit the M8 fitting. I cant seem to remove the fitting at all?
it appears to have a small allan key hole but it doesnt turn. Is this a permanent fitting on the braided hoses? I noticed the crossover cable has the same fitting (M8 on one side and M6 on the other)
Is there anyone in a similar boat who has done a DIY job with an M8 fitting that is possible to fit onto the braided hose?
thanks for any help
chris
post-24670-0-34419300-1317036806_thumb.j
post-24670-0-12396600-1317036815_thumb.j
