Magura Pads Sticking..
Dave Sutton
Take the pads out and stick some chain lube, bit of mineral oil or something on the pistion and pull the brake, force the piston back in a couple of times and see if that frees it up. What's it bled with? Water or oil? Water bled brakes tend to need abit of lubrication every now and then as water isn't a brilliant lubricant.
If that doesn't work, try a re-bleed.
Edited by Mikee
