I Need Help
thetank123
hi i am new to trials biking and i have bought a mission prodigy and i no that its not the best bike but it seems fine for me but when i got it my brother mannaged to screw the peddle in the wrong way round and de-thred it and now im stuck on what to buy so that i can ride a gain can someone help
cheers
Did you damage just the pedal or the crank aswell? If the crank is ok you can buy any platform or caged pedal that you like just decide on how much you like to spend.
Now I use DMR V8 because they where on the bike i bought, not brilliant bearings, not the lightest but good grip and ok price...
I have used expedo, alot fancier but also much more expensive...
have a look at
www.tartybikes.co.uk/platform_pedals/c23.html
www.chainreactioncycles.com/Categories.aspx?CategoryID=209&SortBy=SalesRank
have a look at
i damaged the inside of the crank the peddle is fine and im not sure how i manged to do it but i need to replace the crank but im not really sure what to get
cheers for your reply
helicoil? Not sure if you get them that big though.
is helicoil the think that goes inside somthing that has been de-threeded because if it is that might just be what i need
