05 Magura Problem
cunny12345
The pin which secures the piston in the caliper could have detached itself. It's not common but possible.
When you push it back, can you feel anything "clicking" inside? (can't find the correct word)
Or the other way to find out if it's that or just a hard seal / air, would be to see if you can pull the piston out of the caliper. To do that you'd need to undo the bleed screw first.
