Pads Problem ( Tech Trial )
Przemo
Hello
Hello
I got the rear brakes Tech Trial 160 mm REAR :) It is very nice and full of power but i have small problem . Today i was jumping and my rear wheel was moving , because of that i check my wheel again ( to fix problem ) . Rotor from brake is beetwen caliper but now one of pad is touching rotor and another not . How i can fix that problem . Do i should hold some of pad and push brake ?
Can you help me with that . Just write step by step please
Hello .
Ok but im not with that movie .. not really , i saw the movie but there is diffrent brake , Because i moved my pads in, my rotor is beetwen pads looks very good but after using brakes is the same one pads is more in ( near rotor ) . How to fix step by step , I saw that movie but what i have to do take pads off and what next ? on the movie is to easy because man there is using screw driver to push "pads " how i can do it ? in Hope it is magnes there to hold the pads . Can you explain step by step easy for me :)
the brake shown in the video is different however the technique shown in the video apply's to all the brake models,
i have a front tech trial and i used the same technique to centre my pads so i can confirm that it works.
i will have a quick bash @ trying to give a step by step guide, however forgive me if it's not that great as it's something thats easier to show and do rather than explain but here goes,
step 1 : identify which pad is furthest away from the rotor,
step 2 : insert a flat headed screw driver between that pad and the caliper just infront of the pad retention pin as shown in the video,
step 3 : once the screw driver is in place push/lever the pad against the rotor.
step 4 : pull the lever a few times while still holding the pad against the rotor.
step 5 : remove screwdriver and check pad alignment,
if done correctly the pad that was furthest away from the rotor should now be closer to the rotor and the opposite pad should now be further away from the rotor.
if the pads hav'nt moved across enough repeat steps 2 through to 5 again, if the pad's have moved accross to far and the other pad is now rubbing against the rotor just repeat the process again but this time push the other pad in.
hope that explains it a little better.
ez.
edit: YOU DO NOT NEED TO REMOVE THE BRAKE OR PADS INORDER TO CENTRALISE THE PADS
Edited by ezgonzo
