Has Anyone Ever Tried...
dansharpy
Im looking for a cheap back wheel to get my bike rolling, im only just starting trials so dont need anything fancy or even that strong!
Has anyone ever used a revell wheel before? If so are they any good? Im looking at this one: http://www.ebay.co.uk/itm/170664101485?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_500wt_1361
Also does anyone know if i can use rim brakes on this one?
Thanks for any advice!!
You'll find that the rim will be thinner than trials specific rims, and that if you use rim brakes, they'll be harder or not even possible at all to set up on a pure trials frame.
I wouldn't really trust the hub either, but if you're at the bare minimums then I would still recommend buying a second hand trials wheel from here. It'll be better in the long run, as it means you can progress/improve and get used to the wide rims quicker.
Edit: Just read the post above mine and it's pretty similar to mine haha, well it's good another forum member is thinking alike. blushing.gif
Edited by OnzaKid
