AndrewG Posted September 21, 2011 Report Share Posted September 21, 2011 (edited) Well as topic name says I´ve got problem with my new chain. it´s the same size and nearly same model as I had before(KMC Z610 HX) and now I´ve got KMC 510HX. tarty says that 610´s are 3/32 and mine 510 is 1/8 but they looks same so I think they both are 1/8. but it´s not problem I think because chain fitted on sprocket and freewheel perfectly. I´ve got vertical dropouts so I´ve got sprung home made chain tensioner but it works perfectly too. Chain skipping on rear sprocket. I had the same problem before when I bought 3/32 chain but as I can see now it wasn´t problem. Chain is now little shorter than was old one (because of stretch) and that´s should be better but it´s not. Any ideas what can help me ? Edited September 21, 2011 by AndrewG Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted September 21, 2011 Report Share Posted September 21, 2011 Either time or better chain wrap bro Quote Link to comment Share on other sites More sharing options...
AndrewG Posted September 21, 2011 Author Report Share Posted September 21, 2011 (edited) Either time or better chain wrap bro it´s wrapped better now than before so it´s not problem. And 5hours of riding is enought I think Edited September 21, 2011 by AndrewG Quote Link to comment Share on other sites More sharing options...
planet x alan Posted September 21, 2011 Report Share Posted September 21, 2011 Sounds like either there's not enough tension on the tensioner spring, or you may need a new sprocket. Quote Link to comment Share on other sites More sharing options...
Pete.M Posted September 21, 2011 Report Share Posted September 21, 2011 I have this problem too. Plenty tension, plenty chain wrap, aligned fairly well, good quality chain and sprocket, but it still occasionally skips/jumps. I'm at a loss with it. I can only think that I need to change the tensioner in some way, perhaps run the chain under both wheels? Less chain wrap but I know it worked for one person on here... Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted September 21, 2011 Report Share Posted September 21, 2011 my chain clunks onto my sprockets rather than sinking smoothly onto them, i think thats just down to me having a new chain and old sprockets though Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted September 22, 2011 Report Share Posted September 22, 2011 Stuff Pics of setup? Quote Link to comment Share on other sites More sharing options...
AndrewG Posted September 22, 2011 Author Report Share Posted September 22, 2011 here Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted September 22, 2011 Report Share Posted September 22, 2011 I would say chain wrap, but you could try flipping the rear sprocket over to check it's not tooth wear (if there is enough space for the chain to fit). 1 Quote Link to comment Share on other sites More sharing options...
AndrewG Posted September 22, 2011 Author Report Share Posted September 22, 2011 (edited) I will try it for now thanks well it was because of tooth wear. I flipped a sprocked and it´s working perfectly now. big thanks adam! Edited September 22, 2011 by AndrewG Quote Link to comment Share on other sites More sharing options...
Crtd Posted September 22, 2011 Report Share Posted September 22, 2011 I had similar problems back than. It should be a worn-out sprocket. Buy a new one one or a tensioner which can make more chain links contact with the sprocket. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted September 23, 2011 Report Share Posted September 23, 2011 Good stuff Quote Link to comment Share on other sites More sharing options...
