Pure Posted September 14, 2011 Report Share Posted September 14, 2011 Currently running HS22 maggys on the back and front and I'm not happy at all with the TPAs, they seem to do nothing at all but just spin, no change in resistance or anything - and yes I have bled my brakes, with water, and there is never a difference I've looked on the trials wiki on how to change the plastic TPA to a bolt but I just can't visualise it, anyone got a better way of explaining it, maybe with pictures? Cheers! Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted September 14, 2011 Report Share Posted September 14, 2011 The 04 maggy's where prone to tpa not working, fix guide >>> 1. remove lever and tpa 2.tap the tpa hole 3.use the correct size bolt instead 4.you have a tpa I presume you miss typed hs22 and you mean hs33? Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 14, 2011 Report Share Posted September 14, 2011 You don't have to tap anything - I did "The TPA Bodge" to someone's bike mid-ride using an allen key and a bolt... Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted September 14, 2011 Report Share Posted September 14, 2011 That was just one of the ways to do the fix. Id hardly call it a bodge if you do it properly. Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 14, 2011 Report Share Posted September 14, 2011 I meant that any 'normal' M5 bolt will fit the block the TPA threaded section goes through, so you don't need to really do anything to it. Quote Link to comment Share on other sites More sharing options...
Pure Posted September 14, 2011 Author Report Share Posted September 14, 2011 (edited) The 04 maggy's where prone to tpa not working, fix guide >>> 1. remove lever and tpa 2.tap the tpa hole 3.use the correct size bolt instead 4.you have a tpa I presume you miss typed hs22 and you mean hs33? Nope, I meant hs22! These badboys, pretty old, think I have white hs33 04's for the front but the paint has worn away where the logo and that would be But the TPA is the same in the picture - the red star that always gets knocked -.- Cheers guys btw! Edited September 14, 2011 by Pure Quote Link to comment Share on other sites More sharing options...
