RGH450 Posted September 14, 2011 Report Share Posted September 14, 2011 Hi I have just brought my first bike a 2nd hand Echo pure but the bottom bracket lockrings keep coming loose. it looks as if when both lockrings are tight the one side (o ring side) is not tight on the frame as you can rotate the o ring, but bottomed out on the spindle? there is a spacer on the other side (sprocket side) Do I just need a thicker spacer to allow the lock ring to tighten on the frame or am I just doing it all wrong? Any help or ideas would the good Quote Link to comment Share on other sites More sharing options...
ogre Posted September 16, 2011 Report Share Posted September 16, 2011 loc tite Quote Link to comment Share on other sites More sharing options...
Silferme Posted September 16, 2011 Report Share Posted September 16, 2011 (edited) blue loctite Edited September 16, 2011 by Silferme Quote Link to comment Share on other sites More sharing options...
RGH450 Posted September 16, 2011 Author Report Share Posted September 16, 2011 Looks like i have sorted it, took a couple of mm off the lockring overall length, it now tightens onto the frame Quote Link to comment Share on other sites More sharing options...
