trialskidy Posted September 12, 2011 Report Share Posted September 12, 2011 Hello i currently have the onza t vee and looking for a new frame and have £100 max for the frame is the onza blade 2009 frame better then the onza t vee...? Quote Link to comment Share on other sites More sharing options...
trials owns Posted September 12, 2011 Report Share Posted September 12, 2011 (edited) i went from a t-bird (basically the same as a t-vee) to a blade frame and never looked back EDIT when i swapped mine, the rear rim was too thin for the frame causing it not to have the best braking performance (but still worked fine with beefy pads) Edited September 12, 2011 by trials owns Quote Link to comment Share on other sites More sharing options...
trialskidy Posted September 12, 2011 Author Report Share Posted September 12, 2011 1 other thing would i have to get new bearing for the fork's and headset or does it come with them Quote Link to comment Share on other sites More sharing options...
trials owns Posted September 12, 2011 Report Share Posted September 12, 2011 (edited) no, its just the frame itself, so if u want a new headset it will have to be bought Edited September 12, 2011 by trials owns Quote Link to comment Share on other sites More sharing options...
trialskidy Posted September 12, 2011 Author Report Share Posted September 12, 2011 where can i buy the bearing's on there own that i put in the fork place " i know nothing bout bike's" Quote Link to comment Share on other sites More sharing options...
trials owns Posted September 12, 2011 Report Share Posted September 12, 2011 (edited) its called a headset, there on tartybikes. for the blade 09 it will have to be a external one. Edited September 12, 2011 by trials owns Quote Link to comment Share on other sites More sharing options...
trialskidy Posted September 12, 2011 Author Report Share Posted September 12, 2011 cheer's for the help sick of the t vee weird frame Quote Link to comment Share on other sites More sharing options...
trialskidy Posted September 13, 2011 Author Report Share Posted September 13, 2011 another thing would i have to get new bearing's for the crank? or could i use the old 1's? Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 13, 2011 Report Share Posted September 13, 2011 Assuming you mean the bottom bracket you'll have to measure how wide it is. If your ringing Tartybikes up for a headset though it's probably worth asking them as they may know. Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 13, 2011 Report Share Posted September 13, 2011 I seem to remember the T-Vee had 20" wheels front and rear (rather than a rear 19" wheel), so you'd also need a new rear rim/wheel and tyre. The headset and bottom bracket would switch over reasonably easily though. Quote Link to comment Share on other sites More sharing options...
