Gears Question.
Matt Vandart
I want to put a 24t chainring on my zebdi.
I have a hope trials hub with 6 gears from 12-17t.
I want to put the 24t on to make my bike more ridable if you get me, so I can go places.
What I was wondering is can I make a cassette up between 12t and 19t on a six speed hub?
If so, where would I put the 2 tooth step ups?
12/13/14/16/17/19?
I have no idea
Thanks in advance of your esteemed wisdoms.
Cut apart the cassette, extract all the plastic spacers and the two sprockets you need, and put them on. You might need part of a singlespeed kit to get it to fit properly.
You need to put the sprockets so they're two shifts apart, if you see what I mean, maybe more, cause the chain is quite thick and it won't fit if you keep them as close as they come on the cassette.
Then you hook up your derallieur, wind up the locking screws so it can't go off either edge, and it will work.
