Aidan97 Posted September 10, 2011 Report Share Posted September 10, 2011 im wanting a rear hydraulic disk for my 2010 onza blade after becoming sick of putting tar on. but I was wondering whether id be able to because there's mounts on the frame for the caliper but it doesn't look like there's mounts for a disk on the rear wheel. Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 10, 2011 Report Share Posted September 10, 2011 If the hub isn't disc compatible then no unless you get a new one either built onto the rim or buy a whole new wheel. Quote Link to comment Share on other sites More sharing options...
Aidan97 Posted September 10, 2011 Author Report Share Posted September 10, 2011 If the hub isn't disc compatible then no unless you get a new one either built onto the rim or buy a whole new wheel. im not sure, on one side there's this threaded thing im not sure whether its for a disk or not? Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted September 10, 2011 Report Share Posted September 10, 2011 The other threaded part is for another freewheel for example if one side becomes stripped you can still use the wheel. I suppose you you could make an adaptor, dmr once had a hub with a screw on disc mount all depends on what way your threads are going. < correct me if im wrong. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted September 10, 2011 Report Share Posted September 10, 2011 This is from the description on tarty of the blade. "- Onza sealed rear hub and front open bearing disc hubs are both powder coated white." This sounds like you can use a disk on the rear too. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted September 10, 2011 Report Share Posted September 10, 2011 http://www.on-one.co.uk/i/q/BSSHRT62ROTOR/shimano-deore-rt62-centrelock-160mm-rotor Not sure if this is what you need or not. Quote Link to comment Share on other sites More sharing options...
Rockman Posted September 10, 2011 Report Share Posted September 10, 2011 (edited) http://www.on-one.co.uk/i/q/BSSHRT62ROTOR/shimano-deore-rt62-centrelock-160mm-rotor Not sure if this is what you need or not. That's a centre lock rotor, will only fit the Shimano hubs with centre lock. And no you can't use a disc on the rear wheel of the blade, you would need a new hub. Edited September 11, 2011 by Rockman 1 Quote Link to comment Share on other sites More sharing options...
