How Do I Adjust Snail Cams
Dave Sutton
Undo the rear bolts that hold the rear wheel in place, push the snailcam(s) around until the chain is tight, make sure that the snailcam can push on something. Such as a little bolt that goes through the frame. After you've pushed the snailcam into place then tighten the bolts for the wheels back up.
Does this help?
