liam n Posted September 7, 2011 Report Share Posted September 7, 2011 (edited) eh up lads.....after the onza comp broke, got this, finally arrived from rocknrollbikes today put er all together and the chain rubs on seat stay , and it's constantly rubbing (not just slapping), not bothered out noise etc but will it destroy the frame? don't fancy buying shorter BB (i suppose i'll have to) anyway..pics http://i877.photobucket.com/albums/ab337/liamnorwood/100_2138.jpg check out album for more Edited September 7, 2011 by liam n Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 7, 2011 Report Share Posted September 7, 2011 Looks sweet, glad you FINALLY got it Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted September 7, 2011 Report Share Posted September 7, 2011 About the chain rub, what sprocket are you running? i had that problem on my zoo 20" it does cut into the frame. I simpley changed the sprocket and the problem was fixed. Quote Link to comment Share on other sites More sharing options...
liam n Posted September 7, 2011 Author Report Share Posted September 7, 2011 About the chain rub, what sprocket are you running? i had that problem on my zoo 20" it does cut into the frame. I simpley changed the sprocket and the problem was fixed. no idea, echo...probably TR Quote Link to comment Share on other sites More sharing options...
dann2707 Posted September 7, 2011 Report Share Posted September 7, 2011 Looks good LiamNNNNNNNNNN Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted September 7, 2011 Report Share Posted September 7, 2011 Okay i think i know whats wrong. Take it off, twizzle it round 180 degrees and screw it back on. It'll run VERY close to the spokes but it looks good and works with no problems. It'll probably be VERY hard to get off, i bent a steel bar getting one off my 20" Quote Link to comment Share on other sites More sharing options...
alex-trials-boy Posted September 7, 2011 Report Share Posted September 7, 2011 I had the same problem when i had my limey 20, but one way the sprocket cut into the frame and the other way the chain cut the base of the spokes and would have eventually cut through them new echo tr sprocket fixed that for me but if your using a tr at the mo then a new bb may be the only way to go By the way, Laurence the tr sprockets have an equal distance spacer on both sides i think so swaping it around wont solve the problem, just cause alot of hastle getting it off. Quote Link to comment Share on other sites More sharing options...
josh barker Posted September 7, 2011 Report Share Posted September 7, 2011 i had this exact problem with mine, different sprocket or bb solves it fine Quote Link to comment Share on other sites More sharing options...
F.N.G Posted September 7, 2011 Report Share Posted September 7, 2011 Looks great!, was not good when your onza comp cracked, You were doing so well . How long did it take to get there? Quote Link to comment Share on other sites More sharing options...
TrialsIsHard Posted September 7, 2011 Report Share Posted September 7, 2011 I had this problem, putting the sprocket on backwards sorted it for me Quote Link to comment Share on other sites More sharing options...
JaMmY Posted September 7, 2011 Report Share Posted September 7, 2011 what chain u running lyam ? cause i use to have problems with mine on setting up the brake, wer the pads rubbed on the tyre and matt came up with the idear of putting a half link ,link in a kmc and now it works spot on and the brake sets up perfect Quote Link to comment Share on other sites More sharing options...
Jake. Posted September 7, 2011 Report Share Posted September 7, 2011 Looks great man, makes me want one now haha. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted September 8, 2011 Report Share Posted September 8, 2011 You need a 128 BB with 18:12 gearing to stop the rub mate Quote Link to comment Share on other sites More sharing options...
Rob. Posted September 8, 2011 Report Share Posted September 8, 2011 Okay i think i know whats wrong. Take it off, twizzle it round 180 degrees and screw it back on. It'll run VERY close to the spokes but it looks good and works with no problems. It'll probably be VERY hard to get off, i bent a steel bar getting one off my 20" your well strong lad Quote Link to comment Share on other sites More sharing options...
Sam Moore Posted September 8, 2011 Report Share Posted September 8, 2011 looks nice, on my limey I had to run a trial tech chain, echo tr sprocket and a 122.5 mm bb for the rubbing to stop. Quote Link to comment Share on other sites More sharing options...
