Double Disc Stock.
Wilson.
I ran one for about 2 months on my Yaabaa, had its good points and bad points but I changed back to Magura and I much prefer it.
Bad points:
- Lacks hold on square edges / where load is applied very quickly
- Noticeable weight over rear axle
- Spoke flex
Good points:
- Good hold on rounded edges / where load is applied slowly
- No need to regrind after you get a puncture / change tyre
- Good in the wet / mud
- Silent (good or bad i guess)
I never had it slip out on me or anything. The main problem I had was lack of hold on square edges and the weight. Was very good for rounded rocks eg Dartmoor though.
thanks mate, thats pretty much everything i was after ha, aslong as it doesnt slip then i suppose its worth a try. the bike im buying comes with a mono trial on the rear so even if i dont get along with it i can always switch like you said.
cheers
