shaggy Posted September 3, 2011 Report Share Posted September 3, 2011 Hello. I need to swap a standard axle on a rear iso chris king to a 12mm through axle. Is it just a simple matter of swapping the axles and adding the collar. Or do i need to remove all the internal gubbins to fit the axle. It's been a while since i've had to fiddle with a bike and im starting to doubt myself. I'm sure the standard rear hub axle width is 135mm is that right? Thanks Quote Link to comment Share on other sites More sharing options...
Tomm Posted September 3, 2011 Report Share Posted September 3, 2011 Yeah you can take the axle out without the Chris King tool. Adam Read (of Tartybikes) made some videos of how to dismantle the King hubs - should be useful if you can find them. Quote Link to comment Share on other sites More sharing options...
