Brake Dilemma !
OAP
I've posted a few topics on here in an effort to come to some sort of conclusion for sorting my brakes. Here's my dilemma...
I currently run pre 05 HS33's. These have done me proud and (touch wood) never given me any problems. The only thing about them is the lever length. It's a bit short and i could do with the extra power of a longer lever. I run them with an antifreeze water mix at 70/30.
So i've done some asking about (mainly on here) and concluded the following.
HS33/11 2011 prone to leak with water bleed.
Echo prone to leak with water bleed.
My current HS33's with fresh products lever... can't get hold of the chap (todge I think) who makes them.
conclusion - replace my lever unit with an 05 HS33 and fit with echo sl levers blades from trialprod.
My question is what do you think of my conclusion? I realise some people run the 2011 and echo's with no leaks but i'd prefer not to take the risk.
cheers all :)
I'd keep trying Todge if I were you, or at least hold out 'til someone who knows him comes along to give him a nudge...
Cheers JD. If he is still trading them I'm keeping my fingers crossed he has some pre 05 lever blades. I tried using the email feature on here but got no response. :(
