Freewheel Help!
macpherson88
i have just bought a second hand crank for my bike and im needing to know if freewheels come in different sizes. the thread on the crank in 30mm wide and the thread on an acs claw in 34mm ish .do you they freewheels that are 30mm wide? if anyone could point me in the right direction it would be much a appreciated.
Some Onza cranks use a brass threaded insert for the freewheel section, so it might be worth double checking the person you got the cranks off hasn't accidentally taken that off with their freewheel before they sent it? The only micro-drive sized cranks I know of are the super short Monty ones from the 202 (I think it is...).
its an echo crank. just bought it thinking a normal freewheel would fit. can you buy the onza spacer and if so where?
It's specifically for those cranks. Echo haven't made any crank with a micro-drive threaded section that I know of...
My ZHI cranks require a brass, threaded insert, do you sell them on tartybikes mark?
Unfortunately not, sorry!
I'm not sure in all honesty. The best thing to do if you've taken it off with the freewheel would be to clean the threads up on the insert and crank arm, then use something like threadlock (or some form of glue) and tighten it back on and hope that works...
