Month Brake Spray
mrlynch
Got a light grind my brakes not terrible to be honest just wondering if this stuff is worth a try :)
Yes, IF you use the right amount. You should use four squirts on each side of the rim roll it forward with the brakes on to spread it out then wait for it to dry. I've also found its useful for if you want to ride a slippery surface squirt on, let it dry and ride away :)
Yeah sounds good, also like that idea of using it on a slippery surface. May be good for bit more confidence riding rails? :)
Edited by mrlynch
Im not sure if it works on a grind, no harm in trying though, you just have to ride the stuff, it should only last around a day.
yeah will be perfect on rails, anything metal mainly, becomes very sticky and when the rubber(tyres) go on it, it squeeks a bit just to let you know. As you might expect it doesn't work in the wet though.
Ahh what the hell it's worth a go isn't it. Tar seems to work pretty good with a grind, wondering what its like in comparison really. Cheers for the advice. If its no good on my rim I'll definitely be giving a few rails a coating with it (Y)
Yeah its pretty good just don't use too much as it lock up your feel and the pads literally stick to the rim! Very noisy and a grind id much better but this is a nice alternative. Never used it with a grind but would be interested in knowing how it fares!
Sweet, when I get round to ordering it I'll give an update as to what it's like with a light grind :)
it's utter insane with a grind, until it rains of course. I found it to be worse than tar in the rain.
Sounds good to me! Meh, when it rains I'm indoors so I should be alright :P
Edited by mrlynch
  • 2 weeks later...
Ah well it's ordered now :lol: If it's rubbish I might try some of that then ^_^ almost 4 times the price though!
But I suppose it would last ages.
just tried this brake spray, its pretty impressive once the right amount is applied!
Nice, how often do you have to apply it? Hope it's not every five minutes!
:giggle:
:giggle:
When ever the brake performance is lost (Y) all depending on your set-up eg. grind and pads :)
