G_! Posted August 26, 2011 Report Share Posted August 26, 2011 hi, this is probably a stupid question but... i'll receive a front rock rim in a few days...not sure if that will be 28h or 32h...the hubs i have are 32H and i don't have money to buy a 28h hub...if the rim is 28h, can i mount it with a 32h hub? thanks Quote Link to comment Share on other sites More sharing options...
trialsnoobie Posted August 26, 2011 Report Share Posted August 26, 2011 hi, this is probably a stupid question but... i'll receive a front rock rim in a few days...not sure if that will be 28h or 32h...the hubs i have are 32H and i don't have money to buy a 28h hub...if the rim is 28h, can i mount it with a 32h hub? thanks well yes if you miss out the spoke at 12,3,6,9 o'clock but its bound to crack in on of those spots pretty quickly Quote Link to comment Share on other sites More sharing options...
G_! Posted August 26, 2011 Author Report Share Posted August 26, 2011 well yes if you miss out the spoke at 12,3,6,9 o'clock but its bound to crack in on of those spots pretty quickly thanks mate Quote Link to comment Share on other sites More sharing options...
sayshell Posted August 30, 2011 Report Share Posted August 30, 2011 (edited) I have tried it and it didn't work because if you leave a spoke out then the spacing on the hub flange will have a gap and the next spoke will have to be longer in length to reach the rim. You would need about 4 different lengths of spokes to make that work. I know it sounds confusing but think hard about what I wrote it does make sense but I can't really explain it any better. It might be possible, but unless you know some special way of lacing you won't be able to lace it with a standard 3 or 4 cross pattern. Edited August 30, 2011 by sayshell Quote Link to comment Share on other sites More sharing options...
