Rohloff & Inspired Not Getting Along.
AndrewEH1
Hey all!
Having some issues with my bike. When I moved from using a rear freewheel to a Hope Pro 2 Hub, I also switched from a Trialtech to a Rohloff Speedhub Chain Tensioner.
Whenever I pedal hard the chain skips but it doesn't when I pedal along the road. Took it to my LBS they had not idea. The chain has a good bit of tension in it.
Set-up:
Hope Pro 2 with 14t Sprocket
Rohloff Speedhub Tensioner
Front 18t Sprocket
Image if it helps, sorry for the terrible quality:
http://www.flickr.com/photos/53685602@N07/6080094158/
Edited by AndrewEH1
Need to take the pin out of the back of the tensioner, so it sits closer to the chainstay giving more chain wrap.
You may need a washer under the head of the hanger bolt in this case, to keep the tensioner locked in place.
Top man! It's working great now thanks!
