number1spark Posted August 25, 2011 Report Share Posted August 25, 2011 hi does anyone know if you can use floating brake rotors for trials. any help would be great. thanks Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted August 25, 2011 Report Share Posted August 25, 2011 Not advised. The floating rotors are designed to help stop warping at high temperatures by allowing the rotor to expand as it heats. These are NOT designed for the short, sharp lock braking used needed in trials. I've seen a few posts of snapped floating rotors over on OTN Quote Link to comment Share on other sites More sharing options...
number1spark Posted August 25, 2011 Author Report Share Posted August 25, 2011 thanks, ill give it a miss then. Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 25, 2011 Report Share Posted August 25, 2011 I have used them with no problems. Mine were the older thicker ones though, the uber thin xc ones are not up to it. Quote Link to comment Share on other sites More sharing options...
