Bolt Removal And Helicoiling Help!
macpherson88
just wondering if anyone can help? I have sheered off a bolt in a v brake/magura adapter(4bolt to 2bolt). i could easily drill the sheered bolt out but how hard is helicoiling or is there another way? also stripped some magura threads but have tapped them up a size. havent rode trials for ages and trying to get bike going again as cheap as poss. all help greatly accepted.
Hi mate.. Helicoiling is for repairing damaged thread, not the best option for removing a snapped bolt.
1st thing, how/why did the bolt snap? if it snapped because of over tightening/faulty bolt, then as long as the thread isn't to badly stretched, the snapped off part should come out fairly easily.
If it is corroded in there and snapped trying to loosen it, then it will go hard.
So take the wheel off to give good access, I presume you have the adapter plate off, and the bolt is snapped flush with the frame?
I have seen people get these out by hacksawing a few mm into the mount, through the bolt, and unscrew with a flat screwdriver.
if you decide to drill the bolt, go to the hardware store and get the smallest "Easy-Out" or similar, and the appropriate size drill bit, and attempt to get it out this way.
If you have to drill the bolt out entirely and helicoil it, it is very hard to keep the drill centered on the hard bolt and not dig into the soft alloy casting. basically you drill the whole out to the size of the bolt exactly, tap a new larger thread, then fit a helicoil to reduce the thread size.. not really helpfull unless you can get the bolt out...
If it goes badly, it would probably be easiest to weld up the whole, then drill and tap a new thread in the correct position.
the hacksaw trick would be my choice, but i'm dodgy..lol
Or you might also consider welding a spacer to the end of the broken bolt and use pliers to twist it out? And if you decide to drill it out, you should try to get hold of a reverse drill bit for it. The broken off bolt might even come out while you are drilling with that.
