How Much Psi Should I Run?
F.N.G
If you're gonna let it down till it feels right, start from 50 minimum because high pressures are cool... Then again, being as little as you are at the moment Tom, you'll probably only need about 3psi :P
Haha , it's Not the size that counts it's how you use it ;)
I have pumped it up to 50psi Then I let it down to about 20ish????? (I think?) And it feels great
Thanks guys
Stick with about 20 for a while, it's what most people seem to run.
Don't make a conscious decision about pressure... Leave it until you think, "Gee, I wish I could roll for a bit longer!" or "Golly gosh, these impacts are so jarring!". Change accordingly.
:giggle:
I thought that today when i was hitting the rim on the floor when preloading for sidehops ^_^
