Laurence--Trials Posted August 13, 2011 Report Share Posted August 13, 2011 (edited) Having a few problems with my magura at the moment.. with the tpa and stuff.. So how exactly do i over bleed it? By bath bleeding? New question: Does the piston on the magura need to be lubed with anything when bled with water because when i try to bleed it, it keeps jamming and i have to wait for it to come out.. Edited August 13, 2011 by Laurence--Trials Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 13, 2011 Report Share Posted August 13, 2011 Erm, either works, it basically means pulling the pistons out under water so it draws water in and then shutting the system so it doesn't come out. If you have stiff fitting pads, the old favourite is to put matchsticks under the pads. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted August 13, 2011 Author Report Share Posted August 13, 2011 Okay thanks revolver Quote Link to comment Share on other sites More sharing options...
aener Posted August 13, 2011 Report Share Posted August 13, 2011 Okay thanks revolver Or if you don't have stiff fitting pads, you can clamp some mole grips on the nipple, pull the piston out until you can turn them at 45 degrees and rest them on the prongs that guide the pad out. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted August 13, 2011 Author Report Share Posted August 13, 2011 (edited) New question: Does the piston on the magura need to be lubed with anything when bled with water because when i try to bleed it, it keeps jamming and i have to wait for it to come out.. EDIT: WTF!!! Second pump after the piston comming out and it gets stuck again!! Edited August 13, 2011 by Laurence--Trials Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 13, 2011 Report Share Posted August 13, 2011 When that happens I tend to replace bits. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted August 13, 2011 Author Report Share Posted August 13, 2011 Oh great.. and considering its 05 the piston is discontinued.. I'll try and manage without if not then i may just get the 2011 magura Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted August 13, 2011 Author Report Share Posted August 13, 2011 Sorted the brake, bled it though the lever and out of the slave as appose to the way you do it on your guide revolver. Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 13, 2011 Report Share Posted August 13, 2011 In the guide it says, do it both ways. And in the guide, I also do it both ways. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted August 14, 2011 Author Report Share Posted August 14, 2011 I know, but you start by bringing it though the slave. However there must have been air or something in the lever because when i went though the lever first and out the slave it worked.. Either way my break is good.... for now.. Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 14, 2011 Report Share Posted August 14, 2011 In my experience a stiff piston will always come back. Keep an eye on it. Quote Link to comment Share on other sites More sharing options...
