BradJohnson Posted August 12, 2011 Report Share Posted August 12, 2011 (edited) I took my onza pro out earlier today for its first proper ride and i noticed the front wheel was making a crunching noise, i think its the bearings, does anyone know which bearings i need to put in my onza pro wheel set. Edited August 12, 2011 by bradjohnson Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted August 12, 2011 Report Share Posted August 12, 2011 The front has open cup bearings Quote Link to comment Share on other sites More sharing options...
Azarathal Posted August 12, 2011 Report Share Posted August 12, 2011 The front has open cup bearings You should know this will mean nothing to Brad. Undo the front wheel cones and remove axle, bb's WILL go everywhere if you're not careful. Take one of the ball bearings to a bikeshop / hardware shop and purchase more. Reassemble. Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted August 12, 2011 Report Share Posted August 12, 2011 You should know this will mean nothing to Brad. True, but if the races are damaged, then the hubs a right off (im pretty sure the races in the hub arnt replacable) I wasnt specific, because all manafactures decide to use different size ball bearings :L Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted August 13, 2011 Author Report Share Posted August 13, 2011 I thought the front wheel would of had sealed bearings like the onza blade because it uses the same axel and stupid allen key bolts, and when i put the wheels next to one another they look the same, i'll have a look later one and see what i can do. Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted August 13, 2011 Report Share Posted August 13, 2011 I thought the front wheel would of had sealed bearings like the onza blade because it uses the same axel and stupid allen key bolts, and when i put the wheels next to one another they look the same, i'll have a look later one and see what i can do. Nope, Blade wheelset has sealed bearings in the rear hub, but open cup bearing in the front hub. The front hub should be : http://www.tartybikes.co.uk/front_disc_hubs/onza_open_disc_front/c20p10318.html Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted August 16, 2011 Author Report Share Posted August 16, 2011 Nope, Blade wheelset has sealed bearings in the rear hub, but open cup bearing in the front hub. The front hub should be : http://www.tartybikes.co.uk/front_disc_hubs/onza_open_disc_front/c20p10318.html Fixed. Quote Link to comment Share on other sites More sharing options...
